First time poster here. Any thoughts on what might be issue? It’s with a garage but as it’s so close to Xmas won’t be seen until early Jan. I read some posts taking about cold weather…. I’m sceptical. Likely compressor? Sensor? Just wanted to sound out the community to make sure I’m not getting my pants pulled down.
Multiple parts can be @ fault
both air bellows
compressor
If the the issue just started most likely the pressure is being lost at the airbellows. If this has been ongoing the issued will make the compressor over work. If you change the compressor make sure you change the relay as well.
Most likely when you use it it lift up and after few hours it looses pressure. That will mean the air bellows are not holding the pressure.
Thanks for the help, I was also facing the same issue. Now, I know how to solve my problem and it is all because of you. I would also like to help you or your friend who is not so good at writing an essay assignment. Actually, I found https://writinguniverse.com/free-essay-examples/lying/ website where we can read essay examples for free and because of that website, I never got low marks on my essay assignments.
