Please help ID these lights
I have a chunk missing out of the front skirt below the bumper on my 1995 E420. Instead of going wit the factory replacement, I am thinking about going with the Raceon Hiflex front end. Can anyone help with the lights? I have attached a picture. What should I be looking for to put in the spaces for bumper driving lights? Specific models, sources, and reviews would be great.
The only lights that are located in the E series model you mention are the fog lamps. They are wired to be turned on by the headlamp switch but are only active on the low beam headlights and turn off when the highbeams are on. Be careful with the wattage of the bulbs as the OEM is 50/55 watt and if you put a higher wattage bulb in the glass gets too hot and will shatter!
In the picture above of the Hiflex aftermarket bumper there are lights on the bumper. Below the headlights. Those are the ones I need. I am going to buy that bumper, but it does not come with lights. What model/year uses similar lights? I THINK they are AMG lights, but can't figure out any further.
asweiss
Oct 24, 2010 02:14 AM
MARIODRIVE
Nov 23, 2008 05:39 PM
