Oxygen Sensor
replace it very easy 22mm spanner or 7/8 undo fom exhaust pipe near to cat undo wire .
buy universal bosch unit 50 euros ish and follow the instructions on leaflet on how to connect wires.
you will need to tell your factor if it is 3 wire or 4wire good luck
Thanks,
Actually I went back in my records and found that i had the sensor replaced, but the issue is still occurring, with sputtering and some stalling. The shop that i take has no idea what the problem is,Im at a loss.
