a overheating miracle
Old May 29, 2004 | 03:01 AM
anotherlemon's Avatar
Default a overheating miracle
well i have a overheating problem ....well...i decided to turn the heat on to see if it would cause temp to go down(below 80)and it did...then i turned on the ac to see if it would stay down and it did....the i turned it off to see if it would go over 80 and it did....so i decided to turn the heat on when its cold outside or turn the ac on when its hot outside until i can get it fix....this was truly a miracle
Old May 29, 2004 | 01:07 PM
Lugnut's Avatar
Default RE: a overheating miracle
Thank goodness for the thinkers in the world.
Old May 31, 2004 | 03:15 PM
bbs138's Avatar
it will work temp.only......
you did that and no mechanix have a lunch.........[8D]
deseraligears
Feb 13, 2011 12:03 PM
arlo
Dec 14, 2008 05:55 PM
MASSINC
Oct 14, 2004 01:46 PM
anotherlemon
May 16, 2004 01:53 PM
MaelVardyn
Nov 20, 2003 01:23 PM
