Need some help with Part numbers!
I need part numbers for my car... can some1 please help?
Its an E 300 TD, 1998 year. 606 td ENGINE.
1. Fan viscous clutch
2. Thermo stat valve.
3. Serpentine belt.
4. Fan in front of the condender (the one with motor)
5. Brake switch (to fix ASR/BAS problem)
6. Rear pads.
Would any one know how to tell if the viscous clutch is faulty? and the Thermostat valve? Are their any tests thatcan be performed?
Thanks loadz... you guys are champions!
3. Serpentine belt.
6. Rear pads.
RE: Need some help with Part numbers!
http://www.autohausaz.com/search/cat...00016@Mercedes
tstat opens full at 80c
diy of belt on mercedesshop.com resource section diy articles
brake diy on benzworld.org w210 diy section
ohlord
ohlord
for the fan part...the fan should exhibit less resistance (by hand) when the engine is cold...as the engine warms up the fan should be harder to spin (by hand)...if not then the fan clutch is shot.....
