My first Benz- IDLE PROBLEM - Need Help
Old 08-09-2006, 04:08 PM
SuspectZero's Avatar
Default My first Benz- IDLE PROBLEM - Need Help
I just Purchased a 1993 E300 , when i come to a stop, the rpms jump up to about 2000rpm and it sounds like it reving over and over what could it be?????
Old 08-09-2006, 10:53 PM
Default RE: My first Benz- IDLE PROBLEM - Need Help
I think the ICV (Idlle Control Valve) is bad.... and may be some vacuum leak
Old 08-10-2006, 02:47 PM
Thnaks Leon I'll have that checked into .
Old 08-10-2006, 06:28 PM
maybe spark plugzzzzz
Old 08-10-2006, 07:55 PM
well thats cheaper to replace than the idle valve
Old 08-15-2006, 03:15 AM
vytamenc's Avatar
battle cat spark plugs will not cause this. idle speed valve over voltage protection relay and maybe a purge valve sticking open. i have seen lots of purge valve cause a problem like you stating
Old 08-15-2006, 03:18 AM
ORIGINAL: vytamenc
Right, I was thinking 'rough idling,' Ma bad.
Old 08-15-2006, 05:43 PM
It's gottem worse . now the car will stay running as long as im moving over say 30/mph and i can feel it jump while driving , " Car Speed's Itself up" and today sitting at the gas station I was in drive with brake on and my car continued the dreaed idleing and then RPM dropped and car turned off. this happend 3 times. SO Now im haveing a hard time keeping the car running at a stop .....
  #9
Old 08-15-2006, 05:51 PM
I have a 1993 300E as well with a 2.8 V6,,, the idle is doing the same thing, when i start it up in jumps from 400RPM to 800RPM and goes back and forth... The check engine light is on, however I'm not sure how to check that... anyone know?
  #10
Old 08-15-2006, 06:07 PM
the thing is that there are no other indicators in my car , as in no check engine lights or anything.
Quick Reply: My first Benz- IDLE PROBLEM - Need Help
