to master SLEEPWALKER-HELP please
P L E A S E G I V E ANY TIPS ,ADVICES I WILL DO EVERYTHING TO GO THRU WITH YOUR CLUES AND ADVICES
I tried write a post to you many times ,but i was just reposting in my first one
I hope you will respond to this one
Dear Sleepwalker,
I GOT FEW PROBLEMS ON MY 1997 E320
I HAVE CODE P0410 SECONDARY AIR INJECTION -HOW DO I FIND IT OUT IF IT IS AIR PUMP OR SOMETHING ELSE
AND ON NEUTRAL WHEN I TRY REV IT GOES ONLY TO 3700 AND START SHAKING AND DOESN'T REV MORE ,BUT WHEN I DRIVE IT IS OK IT GOES TO RED LINE VERY EASY
AS THIRD OF MY PROBLEM IS AC - I DID SOME BLEEDING AND REFILING AND AFTER WAS OK ,BUT AFTER JUST ABOUT A WEEK LATER THE BLOWER(FAN )DOES NOT GO TO HI
JUST BLOWS JUST ABOUT MEDIUM - I DON'T KNOW IF THIS IS JUST COACCIDENT OR MY TOUCH WAS INVOLVE
IN STATE FLORIDA I AM FRING UP I HAVE TO START CAR AND RUN ATLEAST FOR 30 MIN TO GO IN
NOW QUSTION OF THE YEAR -I WILL BE WORKING ON MY CAR DOING A LOT OF WORK IN IT LIKE COMPLETLY NEW AC ,ALTENATOR ,WATER PUMP,DISCS BREAKES,ETC AND ALL KIND TUNE UP HP"DO I HAVE TO WORRY ABOUT LOOSING SOME CODES ON MY ECU ,PROBABLY MY ECU AND BATTERY WILL BE REMOVED ?
IT DID HAPPEN TO ME IN CADILLAC I DID REBUILED AND NO ONE COULD START MY AC AND I HAD TO PAY 700 FOR PUNCHING FEW NUMBERS CODES TO COMPUTER
THANKS FOR ALL YOUR EFFORTS
Dear Sleepwalker,
1st it could be alot of things with your air injection relay, pump, could have a vacuum hose loose not allowing the switch over valve to activate the air injection valvesyou need to have a activations test done at the dealer. you may even have a bad o2 sensor not droping below 40 mv.
second you have whats called a rev limiter on your car i call it STUPID PROTECTION. its in place to stop STUPID PEOPLE from over reving there car in park or neutral. this is normal you paid for this option.
thirs it sounds like you need a ac blower speed regulator i just happen to see one on e bay a few hours ago the part number is 140 821 84 51.
dont worry about losing anything when your battery is disconnected(maybe throttle position just leave key on for about 5 min. after reinstalling battery) oh any you will need to reprogram your windows one touch feature but not a big deal.
MARIODRIVE
Nov 23, 2008 05:39 PM
C280
Apr 19, 2007 07:06 AM
