Lamp Malfunction
Old May 31, 2009 | 07:14 AM
randy78045's Avatar
Unhappy Lamp Malfunction
Greetings all... I have a 2001 Mercedes E320 which recently displayed the lamp malfunction notice on the dash. I replaced a lamp for the break light which was needed, however the warning notice doesnt go away. I've checked every other light at least three times and they're fine. Does this warning have to be manually reset? If so, how do you do it? Thanks in advance for any help you can give me...
Old May 31, 2009 | 09:48 AM
Scuddog's Avatar
Default Night moves
This can be frustrating. In the evening, have someone help you to check out every single light... headlights, low and high... side lamps... turn signals ft and rr.... fog lights.... rear fog light...(I trust you know which one this is) Back up lights, brake lights, lights that illuminate the area under the doors when they are opened.... interior lights.... good luck! You will find it somewhere!
Scuddog
Old May 31, 2009 | 10:09 AM
randy78045's Avatar
Thanks... i'll give it another look... didnt pay any attention to the interior... maybe it's there...
Old May 31, 2009 | 05:34 PM
chassis221's Avatar
light out indicator has nothing to do with interior lights. could be a tag bulb or side marker usually. or your rear taillamp assemblies are bad and need replacement. the warning comes on when it is activated, if you hit the brake and the warning comes on its a brake light . turn signals on and it comes on then its a turnsignal bulb, same with park lights and headlights. the warning wil come on when that bulb is turned on. If it is a tag bulb, on your car you have to remove the trunk liner panel on the inside of the trunk lid, there are no screws to remove the tag bulb lens so the trunk lid liner has to come off to replace the bulbs. should just do both of them while your in there.
Old May 31, 2009 | 06:48 PM
Scuddog's Avatar
Default Forgot that one!
Ouch! Forgot about the license plate lights. They are hard to see and are small. You may have to squat down to see them. They are not that hard to change. Good call from the previous poster.
Good luck!
Scuddog
Old May 31, 2009 | 10:12 PM
randy78045's Avatar
Ok... I revisited the rear break light that i had replaced... wasnt working again... i pulled out the bulb recepticle and pryed up the three metal contacts and reinstalled it... no more problem... seems the bulb holder just wasnt making good contact... thanks all... mission accomplished...
angiebee1109
Jun 16, 2009 07:14 PM
blmurphy
Aug 1, 2007 07:20 AM
02cl55
Mar 29, 2007 04:04 PM
mbmiller
May 5, 2004 12:02 AM
Andrew
Nov 6, 2003 09:25 PM
