Intermittent Loss Of Acceleration
Old May 9, 2013 | 04:28 PM
j1981z's Avatar
Default Intermittent Loss Of Acceleration
I have a 2001 E200K Tiptronic Estate with 110,000 miles on the clock.
Recently it has started to lose power / acceleration.
For example, driving along at 50mph if I depress the accelerator pedal further down nothing happens, the revs start to drop as does the speed. It feels alot like depressing the clutch pedal in a manual car. If I press the pedal further the car then accelerates as it should.
It does not happen all the time but seems to be getting more regular. At all other times the car seems fine.
Any help would be much appreciated.
Cheers, James
Old May 9, 2013 | 08:10 PM
chassis221's Avatar
Originally Posted by j1981z
Cheers, James
my first guess would be the throttle position sensor, at some point the check engine light will come on. sometimes if you floor the pedal a few times while the issue is occuring you will get a check engine light. Ive replaced many TPS for this condition.
usually the car is ok if just driving slowly to normal, but applying more than half throttle quickly usually the problem will occur.
then cycling the key will usually correct the issue again.
jsd3024
Nov 24, 2013 07:24 PM
MedicDave
Nov 15, 2013 06:46 AM
j1981z
May 13, 2013 08:01 PM
cab262
May 2, 2010 09:11 AM
burwellassoc
Jan 11, 2008 09:18 PM
