I just bougth a e420, just a few things I need to get.
Where is the best place to buy bulbs, I need the Right fog light and the 3rd brake light? Any suggestions? Also on the instrument panel where the speedo is, the right side seems dim, I think it needs a new bulb, where the clock is, is this an expensive fix??
RE: I just bougth a e420, just a few things I need to get.
Go to kragen or pep boys for the bulbs-I use sylvania for all the bulbs. As for the panel, you can try rotating the dimmer switch or pull out the cluster and replace them-inexpensive if you do it yourself (buy the cluster hooks.)
ARMENDS500
02-12-2008 05:58 PM
