How do I remove antenna motor in E320 ?
The antenna motor runs in my 95 E320 but the antenna does not go up or down. I bought an antenna mast to install, I removed the old mast but the nylon geared part of the antenna that I removed is not as long as the new antenna's . So I guess the nylon part has broken in the motor housing and needs to be removed. SO how do I remove the entire motor so I can open it up and see if the nylon strip is stuck inside of it.
Question number 2
The driver side sun visor does not light up, I removed the mirror part to get to the light bulbs , they are fine, I narrowed it down to the small blue box where a wire runs into , then another wire runs out of , there is power from the wire running into the box, but no power coming out of the box. Is there a fuse of some kind in this small blue box, or how do I replace this part?
Thank you.
Question number 2
Thank you.
car5car
Aug 22, 2011 09:17 PM
