hi all from ireland
i need help with my merc, I have an e280v6 1998 model avantgarde and my asr and cruise control just stopped working???? the warning light on the dash is staying on.
RE: hi all from ireland
only the ASR light is on?
hi sleepwalker, yes the BAS/ASR light is staying on when i turn the engine. this happened as i was driveing my car,
The cruise control is not working now as well as the ASR? |
Have you made any changes to the tires/wheels?
Have you checked the PSI of each tire? Just trying to eliminate the easy stuff first... |
how d, i sorted the problem today, It was a brake light switch that was faulty so i replaced it with a new one and the asr is back to normal and the cruise control is fine. I need to know the code to rest the service interval on the dash??
I suspect the ribbon connector (mechanics call this part the "clock spring" because it looks like a clock spring) in the steering wheel column is failing. If the wheel is turned to the stops it stresses the connector and they will fail. To repair it you have to remove the steering wheel and airbag system. It is very important to install the new part correctly or it will fail. There are other indicators of this failure. The items on the steering wheel will begin to become erratic. The horn button on some will also become erratic. If I remember correctly the cruise set buttons are on the steering wheel. Check this out hope it helps. Jim
