Headlight lens faded & dingy
RE: Headlight lens faded & dingy
All sorts of things have been tried from acid etching to Vinegar and as far as I know there is no repair that is adequate. The junk yard is an excellent place to get new lights (that are not frosted, otherwise don't buy them). I did not know that MB had this problem, what year and model?
Buy new ones I replaced the fog light covers on 90 300E looks brand new, they were not to expensive and considering they lasted 15 years the first time in 2022 you might have to replace again.
Wal*Mart sells the very thing to cure this sort of ****. When you go, look in automotive dept. (It makes sense AutoZone carries it too.)
Last time I checked....it was $20 per pack. Inside the package, there are three or four towelettes that are presoaked with different chemicals.
They are expensive. So read up carefully before you start wiping. I would wear a pair of gloves too. Chemicals!
Check out this product. It works pretty good for me.
http://www.meguiars.com/?clear-plast...Cleaner-Polish
Also look up Mother's Plastic polish, and PowerBall. Thay look like they do a good job together!
Good luck~!
Good luck~!
JulzXhulio
06-18-2013 09:37 PM
