Fuse Replacement, which one?
Old Dec 13, 2003 | 02:00 AM
gotsu's Avatar
Default Fuse Replacement, which one?
I now realize that the fuse is out
for the AC LCD/buttons, which is why
it stays out in the evening.
Anyone has a clue which fuse to replace?
Thanks,
Stanley
Old Dec 17, 2003 | 11:00 AM
Nello's Avatar
fuses are located under the bonnet and under the hood/bonnet, they are all well labelled.
Old Nov 9, 2007 | 02:40 PM
rcg's Avatar
rcg
Default RE: Fuse Replacement, which one?
Hi, I have 2000 E220 CDI model and the fuse layout chart is in German. Does anyone have a fuse layout in English for this W210 E class vehicle
Old Nov 10, 2007 | 08:32 AM
RichardM98's Avatar
Did you check both sides? Mine is German on one side and English on the other. If not the E320 has three fuse panels. One under the hood, on the left front pillar (dash) and one under the right rear seat. Which one do you need?
Old Nov 11, 2007 | 12:11 PM
rcg's Avatar
rcg
RichardM98 - Thanks forthe response. I checked the fuse box but can't find a fuse for the illumination on theClimate control panel on the centre console. Looks likeit could be a bulb failure. Does the climate control have replaceable bulbs or is the control illuminationnon-replaceable/sealed into the climate controlunit?
The various controls appear to be working fine. Has anyone been faced with a similar problem?
Old Nov 11, 2007 | 06:49 PM
RichardM98's Avatar
If you mean the LCD display I think the backlighting (illumination) is built into the
LCD. I could be wrong so maybe someone else will post. Good luck.
benzguy
Oct 23, 2010 03:33 PM
btorsiello
Oct 26, 2004 07:09 PM
nuwave2000
Apr 14, 2004 01:47 PM
dimple212
Feb 28, 2004 12:11 PM
erictfree
Feb 13, 2004 09:00 PM
