Fuel injector leak
![Unhappy](https://mercedesforum.com/forum/images/icons/icon9.gif)
1998 E320 160,000 miles
Got an error code P0170. Detected a vacuum leak (carb cleaner) on 2nd injector on pass side.
Removed fuel rail, changed o rings; leak was 2nd cylinder (a little) but mostly now on 1st cylinder(pass side).
Removed fuel rail; moved those 2 injectors to other side (to eliminate possibility of it being injector). I cleaned port hole with a nylon brush on a dremel (didn't want to use hone or wire because I'm concerned with grit or wire getting in cylinder - if something can go wrong it will)
new o rings -oiled b4 insertions, and there is no change, except maybe #2 is worse now.
There appears to be a position for 2 o rings on injector, yet only one is used.
1) I don't know what else to do
2) I really don't see the harm in putting in another o ring and trying those problem injectors with 2 o rings.
Before I take it apart again, I thought i'd check in with the really smart guys f some advice
Any thoughts
Any thoughts
I got error code P0170. sprayed around with carbeurator cleaner. car almost stalled at cylinder 1 ... was noticeable but not quite as bad on cyl 2. I tried isolating intake from fuel rail when i sprayed. I is on intake side
Any chance the leak could be coming from around the MAF? I think if one of your injectors was leaking that badly, there would be fuel spills. Aren't the injectors pressurized anyway? I dont think they would have that much of a vacuum if any at all.
Oh, I wish it were a simple solution. I've gone through 3 cans of carb cleaner, spraying everywhere f a vacuum leak. The only place I can find is directly where injector goes into manifold.
I will go back and specifically check MAF again, but i'm pretty sure I've isolated it.
Car runs ok, but I have the error code with ' check engine electronics' alert on dash.
