Flshing Mirror and Dome lights
Members,
I have a 2005 e320 cdi and it just began alternating interior flashing mirror and convenience (dome) lights @ ~1Hz. I pulled the battery to reset and seemed to work for a while, then restarted. Last night, all the interior dome lights turn on, then soft turn off, just to cycle back again.
Any clues as to what is going on or what I should be looking for?
Cheers!
Larry
Cheers!
Larry
Members,
Cheers!
Larry
Cheers!
Larry
Answer
The most common issue is a failed Signal Acquisition Module, your car has two.
The Signal Acquisition Module in the engine compartment has been superseded nine times on your car.
MB# 2115457801
The Signal Acquisition Module in the boot (trunk) has been superseded seven times on your car.
MB# 2115459301
As a precaution, you should also have the alternator, and both batteries tested.
FYI: The battery control module in the trunk also has issues, superseded six times.
MB# 2115408645
roy@pelicanparts.com
MB# 2115457801
MB# 2115459301
MB# 2115408645
Response to Roy
Roy,
Excellent feedback. MB dealer was clueless as to where to begin looking, with no obvious error codes.
Batt/Alt were ok. - that was my concern as well.
I think that it was precipitated the cascade of issues was the heavy heat we had in the NE that week and the hard driving.
When you say "superseded", you mean new revisions have been made. Are these revs compatible with my model/year?
Cheers!
Larry
Cheers!
Larry
Answer
Roy,
Cheers!
Larry
Cheers!
Larry
When EPC specifies a component has been "superseded" = MB has verified fit function of the replacement.
Frequently the older number units are pulled back from dealer and warehouse for destruction.
FYI:
Each time MB has superseded a module, their generic internal cost is a minimum of $150,000.00 USD, and can easily go into the millions of USD if safety testing and government re-certification is involved.
Obviously there are issues with previous design units.
C220Freak
12-26-2009 09:38 PM
plutoprime
10-10-2007 04:50 PM
