Flat spot
Old May 8, 2006 | 09:36 AM
Sean's Avatar
Default Flat spot
Hi all great site! New here, I have an 2000/E240 v6 drives fairly well but when I put the boot down there is a lull, a realy then it comes in like a bullet way up in the revs , anyone an idea wots up?
Old May 8, 2006 | 12:28 PM
sleepwalker's Avatar
Default RE: Flat spot
can you speak in english please?
i am guessing that you got noise when you accelerate?
a whining noise?
maybe alternator?
if you remove the belt... does the noise still exist?
Old May 8, 2006 | 03:41 PM
mgw_300e's Avatar
ORIGINAL: Sean
I think he means that when he tries to accelerate quickly, the car hesitates as if he hadn't stomped on the gas, then after a second or two, the RPMs go shooting up - almost like there's a delay between the pedal and the engine.
Does that sound about right Sean?
Old May 8, 2006 | 05:15 PM
Sean's Avatar
Yes you got it in one!, thats exactly what its doing, there is at least a second or more before it response
Old May 8, 2006 | 05:28 PM
Sean's Avatar
Sorry Sleepwalker! will try and improve the English
Old May 8, 2006 | 06:36 PM
mgw_300e's Avatar
ORIGINAL: Sean
I just wish I had an answer for you. I think your car has an electronic throttle instead of a throttle cable, so maybe there's some problem there.
Old May 9, 2006 | 05:46 AM
Sean's Avatar
Thanks for your reply, I wonder the problem could be the Air flow meter? Its actually worst when I switch the gear box from winter to summer setting....Anyway it sounds expensive!
Old May 9, 2006 | 06:44 AM
Air flow meter
very possible.
Old May 9, 2006 | 12:48 PM
  #9
leon s.'s Avatar
Hi Sean,
I have the same problem but not as strong as yours. I had low idle on my car and the mechanic adjust the idle by enriching the idle mixture (he adjust the screw in the middle of the air filter box with a long allen key). After that the idle is a bit better but time to time (not all the time) the car hesitates a bit on take off from a stop light. I keep an eye on that and may bring it back for more adjustment.
I would suggest that you look at the idle mixture and my guess is when you press on the accelerator, there's too much gas that's why the car hesitates. I hope this will help.
Old May 10, 2006 | 01:43 AM
  #10
he got 112 engine. ME
your's could be 103. CIS
