exchange cabin air filter on E320 -01. 4 filters?
Old 02-22-2006, 01:57 PM
stimpen's Avatar
Default exchange cabin air filter on E320 -01. 4 filters?
Im going to exchange the cabin air filters on my E320 -01. And I have some questions if someone can help me.
Where are these filters located? I have searched the forum and only found 1 post that said they are located under feetpanel at passanger side... But are all the filters located there? Read on what mercedes told me :
I have called mercedes and they have told me there are 2 regualar filter and then there is a charcoal filter or maybe 2 didnt ask how many charcoal filters there was? Dosent feel like all of them are at the same spot?
Had a bmw 5 series before and they had 2 filters also, one at each side of enginebay below windscreen.
I have the large automatic ac system with a display and buttons around it.
The pair of regular filters shall be exchanged every B service and the charcoal filter(s) shall be exchanged every second B service is this the correct exhange periods?
Is this a American forum? My car is built for German market so I dont know if there are any diffrens to the American versions but at this point I doubt there should be any.
Finally I would ask what is the modelname on a E class -01 and what is the enginecode/name for the E320 engine.
Old 02-22-2006, 02:08 PM
snanceki's Avatar
Default RE: exchange cabin air filter on E320 -01. 4 filters?
Cabin air filters on passengers side above NVH closing plate.
Dead easy albeit a little tricky to change if you get on your back in the footwell.
need to move closing panel. A couple of screws then move panel towards bulkhead. then pull end nearest the screws down towards footwell and it should come away.
Your info appears correct re filters.
You remove the filters by sliding "clips" along the filter housing. Will send you a pic if you have problems but don't have time at present.
Will leave the others to answer model definition. I only know my own model w210 I think.
Old 03-02-2006, 04:22 PM
stimpen's Avatar
lifting topic if anyone knows the engine name/code for the E320 -01
Old 03-03-2006, 05:48 AM
sleepwalker's Avatar
you got the VIN?
i can give you all data.
Old 03-04-2006, 09:27 AM
stimpen's Avatar
hi. my vin nr is WDB2102651B207810
Old 03-04-2006, 10:11 AM
VIN WDB2102651B207810
Plant 50
Model E 320
Chassis 2102651B207810
Engine 112941 30 809237
Transmission 722618 02 334459
Tyres
Primary CONTINENTAL
Rear MICHELIN
Order 0 0 214 15223
Lights HELLA
Axle
Forward 00795808
Cab 00000
Delivery date 28.07.00
Dealer Dortmund branch (214)
Interior leather "nappa" two-color anthracite+anthracite (251)
Paint
197 obsidian black metallic (ั 1978)
Options
X57 leather, designo-linarite blue, two-color (ั 06.02.1998)
021 designo - leather (ั 05.02.1997)
214 electronically controlled damping system (ADS) (ั 01.03.1994)
220 parking aid (ั 01.10.1993)
242 right front seat electrically adjustable with memory feature. only applicable to series w 210 when installed in conjunction with code 275. (ั 01.03.1983)
249 automatically dipping inside rear view mirror (ั 01.06.1990)
260 elimination of model designation on rear lid (ั 01.05.1968)
275 front seat positioned lower
memory package (driver's seat, steering column, mirror) (ั 01.10.1993)
289 wooden/leather steering wheel (dia. 390 mm)
wood-/leather steering wheel (ัˆ 390mm) and leather gearshift (ั 01.02.1993)
multiple contour backrest for right rear single seat
293 trunk set, 3-piece
sidebag in rear left and right (ั 01.01.1995)
304 elimination of front ashtray (ั 01.01.1990)
345 rains sensor for windshield wipers (ั 01.10.1993)
352 operation and monitoring system comand (navigation + radio/cassette) (ั 01.09.1996)
354 antenna on roof centre rear for mobile D-net telephone
antenna on roof centre rear for standard D-net telephone (ั 01.10.1994)
401 comfort front seats with ventilation and seat heaters (ั 01.01.1996)
404 left front seat with multiple contour backrest (ั 01.01.1996)
405 right front seat with multiple contour backrest (ั 01.01.1996)
414 electric tilting/sliding roof in glass version (ั 01.10.1988)
423 5 speed automatic transmission / nag (ั 01.03.1994)
481 undershields (ั 01.10.1962)
500 outside rear view mirror left and right, folding (ั 01.10.1993)
543 sun visor with vanity mirror, illuminated, left and right (ั 01.11.1978)
581 automatic climate control (ั 01.01.1977)
600 headlamp wiper/washer (ั 01.08.1971)
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (ั 01.11.1978)
612 lamp unit: gas discharge lamp (ael)
xenon headlight (ั 01.10.1993)
645 M+S tires (ั 01.10.1963)
673 high-capacity battery (ั 01.01.1964)
681 Unknown code
682 fire extinguisher (ั 01.04.1970)
691 blue heat-insulating glass all round, rear window, single pane safety glass (ั 01.02.1995)
801 Change of year of model, last figure shows new model year
810 loudspeaker, sound package
sound package (bose) (ั 01.12.1986)
819 CD changer - alpine - in trunk (ั 31.07.1992)
853 production test bm 124125 (ั 01.01.1978)
876 interior light assembly (ั 01.10.1997)
877 reading lamp in the rear (ั 01.11.1963)
910 14V/65A alternator
alternator with increased capacity (ั 01.11.1990)
926 emission control eu4-measure 30.11.1991 (ั 09.09.1997)
954 equipment package for avantgarde vehicles (ั 01.06.1993)
rotating emergeny flasher, front (red light)
988 ownership certificate and COC papers with EC model plate (ั 01.06.1993)
Old 03-04-2006, 12:28 PM
BikerDrew's Avatar
All data? Your not kidding.
Old 03-04-2006, 01:00 PM
except for maintenance history.
got no access in carfax.
but if you got Jaguar, Rover or Volvo, i can get it...no problem.
  #9
Old 03-05-2006, 11:11 AM
stimpen's Avatar
sleepwalker thanx for the data. Is my engine called 112 then when enignenumber begins with 112?
I have exchanged the charcoal filters under glovecompartment but I cant get to the dust filters that are right below the windscreen behind the glovecompartment.
How do I reach these filters? I have taken away stuff in the enginecomรฅartment so I can see the filters from there but there is an airvent that prevents me to get the filters that way.
I have taken away all the screws i can see to the glovecompartment including the one under the light. But I cant remove the glovecompartment. Its loose but still it stucks somewhere at the upper edge. Someone who knows what to do? Or how to exchange the dust filters?
  #10
Old 03-05-2006, 02:33 PM
stimpen's Avatar
I succeded at last to exchange all 4 filters. Those behind the glove compartment was really hard when you dont know how to get to them...
Quick Reply: exchange cabin air filter on E320 -01. 4 filters?
