Error Code po410 Secondary Air Injection
Old Jul 8, 2006 | 04:04 PM
mikedee's Avatar
Default Error Code po410 Secondary Air Injection
Within a few days after replacing a coil, my 1997 E320 displayed the error code po410. The car seems to be running fine so it's difficult to pinpoint the the exact cause of the code. When I turn the key to the on position I can hear a fan running, which seems to be associated with the air injection system. It seems to me that this is not normal. Could it be that the code is related to the air injection system? How do I trouble shoot this? Is this a job I should try tackling myself?
Old Jul 8, 2006 | 09:26 PM
coca light's Avatar
Default RE: Error Code po410 Secondary Air Injection
ORIGINAL: mikedee
Hello mikedee and welcome to the forum,
yes, code po410 belongs to the air injection!
Please try to find out which fan exactly starts running???
Actually there“s no correlation to the replacment of the ignition coil, but...
Did You check the pressure converter at the front of the cylinder head cover under the black cover?
Maybe You did something unintended with the plug/hose?
Further You can check the valve near to the generator with the vacuum hose ...
please report, I'm curious about it !
regards
Peter
rzm
Nov 20, 2013 01:33 PM
prusso99
Apr 8, 2012 09:45 AM
S. Jones
Jul 10, 2007 06:22 PM
certs37
May 14, 2007 03:16 PM
Reshad
Dec 29, 2006 07:45 AM
