Engine oil level
Old Sep 10, 2006 | 06:16 PM
mjovolt's Avatar
Default Engine oil level
Hi everyone,
I own an e-320 2000. While I was performing an oil check thru the oil level indicator , I got the following message: " ENGINE OIL LEVEL - REDUCE OIL LEVEL". The reading is right, I think I may add one quater oil to many. I know I have to remove the excess oil. I don't want to drain the excess oil, too messy. If I want to siphon off the oil what is the best way to do it?
Your help would be greatly appreciated,
Thank you.
mjovolt
Old Sep 11, 2006 | 03:49 AM
snanceki's Avatar
Default RE: Engine oil level
If you don't want to use the drain plug (too messy?) you will have to siphon thru the dipstick tube. Suggest you go to a local lube bay and negotiate a price with them.
Stuart
Old Sep 11, 2006 | 07:52 PM
97dmsrS420's Avatar
Ditto!
Old Sep 12, 2006 | 01:08 AM
TSBenz's Avatar
You may want to get a "Topsider." These devices are primarily designed for use in marine applications - but also work great for cars. This weekend I set out to change the oil in my 2000 E430. I put it up on ramps and jacked up the back end of the car to level it... but could not get the drain pug out. It was so tight that my socket slipped and rounded the hex on the drain plug. (should have used a 6 point instead of a 12 point socket... hindsight is 20/20) So, I left it as is and made my way to the marine supply store and bought an "oil changer." I bought an electric model for about $130 bucks...(I will use it a lot on two cars and a boat.) In 10 minutes I had 8 quarts of oil out of the car. I let it settle for a couple hours while I did other things and pumped it again to be sure I had it all. Far less expensive manual models are also available - or even units that use a drill to power an impeller with a hose on either end. I have even seen units for 30 bucks that might work fine for pulling out a quart of oil. The store I went to is West Marine. They have stores around the US and a web site: www.westmarine.com Search on "oil changer" - or look in your yellow pages and find a marine supply store.
tuslac
Aug 9, 2010 09:24 PM
BravoPet
Feb 6, 2010 12:14 AM
sal911
Dec 13, 2009 12:38 AM
leb01amg
May 5, 2007 11:49 AM
