e320 wont start
Hi
this might sound stupid but i'll ask anyway. I took one cable off of battery to clean corrosion and after putting it back, it wont start. All start up test on dash seem to be Ok but it won't crank. Does the key need to be reprogrammed, because it was in ignition when i took the cable off.
Thanks for the help
Thanks for the help
leave the key in the ignition for a few seconds before trying to turn the key. see what happens.
Hi
Thanks for the help
Thanks for the help
Hi, I got 1998 E320 sadan. My problem is almost like yours.. My key can lock and unlock the car but can not turn to start the car. I tried to leave it in the ignition for a night but it still does not work. Is my key just turn bad for no reason. By the way, this key is the one I have not use before because my wife always use hers. Please help
if you are sure the car battery is good. then sounds like a bad remote. but when you switch on the headlights do they come on? you siad you cant pop the trunk from the inside swich? still sounds like battrey problem to me.sometimes a jump start just isnt enough.
I was going to come in here ask a similar question. I have a 1998 E320. This is rare right now, and only happens about once or twice a month. When it happens, I can turn the key and the car will start, but will quickly cut off when it's about to idle. I then turn the key back, start it again, and it runs just fine. The key is fairly new at only a year old, and I can't recall if this has happened with the old one. I'm hoping this is just a small problem that isn't leading to a bigger one. Anyone have any idea what is happening? Figured I would ask this here since it's a similar topic, instead of starting another thread. Thanks in advance.
Hi, Here's an easy one, I hope. '99 E320 running well until yesterday. No crank/start with either battery or jump. Battery voltage is 9.5v. Will new battery most likely fix problem or will something else need to be reset/replaced? Thanks. A quick response is appreciated. My wifes car and she can't go anywhere. Need to fix it so she can get out of the house and quit bothering me.
