E320 Won't Reverse
Old Nov 27, 2017 | 11:19 AM
LCP's Avatar
LCP
Unhappy E320 Won't Reverse
I have a 1996 E320 and if lately, if I am facing downward on a hill/incline/etc. it will not reverse. I just burn rubber. However, it will reverse if I am on level/flat ground. I have had to get pushed twice out of a parking spot in which I was facing down. Is this a transmission issue? Any insight is welcomed.
Old Dec 8, 2017 | 05:14 PM
96SL500's Avatar
From: Manatee County, Florida- Sarasota mailing address
Sounds as if the front brakes or emergency brake is not releasing. Have you tried going forward a couple of feet before backing up. Have you turned on or off the SRS? Summer/winter transmission button (winter has a different reverse gear in cars with this feature than the summer setting which has a higher speed. Just fishing, never heard of this problem on any car, although rear end is usually lighter and might break traction quicker.
Old Dec 8, 2017 | 05:54 PM
PelicanParts.com's Avatar
In case it is your e-brake, take a look at the link below for the replacement procedure. Please let us know if you have any questions!
Mercedes-Benz W210 Parking Brake Replacement (1996-03) E320, E420 | Pelican Parts DIY Maintenance Article
Old Feb 6, 2018 | 03:06 PM
Alex Lopez's Avatar
Default 1996 E320 will not reverse.
I also have a 1996 E320 with about 146,000 miles on her. Just recenetly, like the last few days the transmission seems to be slipping but only in reverse. It does appear to be getting worse. Has anyone figured out what could be the cause?
Old Feb 6, 2018 | 03:52 PM
Apparently this is a common issue with the W210s. Most suggest to first get the car's codes read to see if that turns up anything - others have mentioned that it may have something to do with the rear diff.
js35630
Jun 25, 2011 08:20 PM
markwill
Jan 21, 2008 12:43 PM
speedt1
Feb 11, 2007 06:38 PM
Dehaven
Dec 23, 2006 05:09 PM
pkkill
Mar 6, 2004 11:39 AM
