E320 W211 Lug Bolt Specs
Hi folks:
I am trying to find longer lug bolt for my 2005 E210 W211 CDI. What is the bolt sepc? Is it 14x1.25? I believe for pre-2003 is 12x1.25, but post is 14x1.25? Any hint where is the best place to get them from (I am putting 15 mm spacers, so I believe I need at least 40 mm long ones?)
Cheers,
Farid
Cheers,
Farid
15 is a big spacer,hub centric?
RAD usa/otis google for web site they have sets in proper seat and length.
saved you the trip
http://www.otisincla.com/
about 50bucks for the set.depending on where you live discount tire shops also have lug sets of different length.
saved you the trip
Dear Ohlord!
Thanks for the reply. But, I still do not have an answer weather the bolts are 14x1.5 or 12x1.5?
Moreover, I have got a set of rims that were suppposed to fit my car; however, the front ones, because of the stub coming out of the hub obstruct the star wheel insert. So, I am forced to put a spaceer of 15 mm to allow for the star insert fit. Any commnets?
Regards,
Farid
Regards,
Farid
And installing a 15mm spacer to a proper offset rim to make it fit over the hub is going to push that rim way out to the fender and cause issues not only with the fender but also a lot of stress on the front wheel suspension and bearings.What is the offset of these non mb rims?
