Door panels
How many bolts or clips are holding the front inner door panels in and how do I get to them? I already found two one above the door's storage bin and one underneath the airbag plastic piece. Are the anymore, if so where?
thank you
Eamonn
thank you
Eamonn
under the interior handle to open the door. remove the plastic trim behind the handle. then pop off the panel at the bottom half then pull the door panel upwardsoff the door. also remove the trim piece around the door latch. and the door **** lock.
rich121
Sep 26, 2005 11:04 PM
rich121
Sep 22, 2005 03:00 PM
