Cruise control
Old Dec 13, 2004 | 12:26 AM
boycbronco's Avatar
Default Cruise control
Last post for the night... my cruise control on my 300E. I set it the other day, and the car started accelerating with no sign of stopping. I hit the brake to turn it off, and the cruise control has not worked since. What part of the cruise control system should I be looking at to fix? Regards.
Old Dec 13, 2004 | 12:39 PM
goodluck's Avatar
Default RE: Cruise control
i dont think you have a problem. Try getting the car to 80km/hr before engaging the cruise
Old Dec 13, 2004 | 05:23 PM
boycbronco's Avatar
Goodluck, thanks, but I have tried setting it at any number of speeds, including over 100 kmh.
BCB
Old Dec 14, 2004 | 11:44 AM
goodluck's Avatar
Is your ASR light coming on? if so then that is the cause. Does your car hesitate while moving?. if so try checking your throttle actuator. if your works fine without any hesitation, then try checking the cruise control Amplifier or the reference resistor
Best of Luck
Old Dec 14, 2004 | 11:19 PM
sleepwalker's Avatar
i would like to ask also the same question... hesitation when moving.
Old Dec 15, 2004 | 09:16 AM
boycbronco's Avatar
No hesitation, no ASR light. I'll check the last couple of items you mentioned. Thanks again.
Old Feb 2, 2006 | 06:02 PM
demmy's Avatar
Hi Guys,
What is reference resistor and where can I find it?
budsl600
Feb 9, 2005 12:29 PM
goodluck
Dec 3, 2004 03:39 AM
Randy
Dec 1, 2004 11:48 PM
madrat
Aug 12, 2004 10:31 AM
Jun 8, 2004 10:02 PM
