Covertible top dye
Covertible top dye
I just recently purchased a 2013 E350 convertible. It looks like someone along the way might have used a power washer on the top! Go figure. Anyway I was wondering if anyone has had any experience with using a convertible top dye? I was thinking that perhaps this would help revitalize the tops appearance.
If the fabric is black, you can use Solution Finish. It brings everything it touches back to a factory new finish, especially plastic trim. Also works on fabric, but you'll need to try it on something similar to make sure your using the right applicator to avoid streaking, I use it mainly in engine compartments, interior and exterior trim, and tires, but it works on fabrics as well.
