Climate Control Economy Mode On
You can't shut the light off?Compressor is not going on,you have no r134a,you need to have the system charged partially and the leak located and fixed and then a new drier installed and a complete charge done.Find a good mb indie shop to do the work,the dealer will rape you.
ohlord
http://www.eclassbenz.com/node/27
ohlord
I agree. Local Mercedes / German car workshop will be able to identify the issue in no time. They will check the electrical first then do a leak test if all appears in order. Hopefully it's just a hose or solenoid. If not.... thank goodness for the $1200 check that we are all going to receive! Good luck! [
![Embarrassment](https://mercedesforum.com/forum/images/smilies/redface.gif)
ya you have to get it reset by a dealer...the line that always leaks on your car is the small high pressure line from the condensor to the dryer...its located on the left front..pretty easy to change...will need to be charged
1al@automatedvending.biz
05-19-2011 02:01 PM
