A/C noise
At times, there is a whirring noise that sounds like it is coming from the A/C. The noise fluctuates with the engine (higher throttle, more noise and less throttle, less noise). If I turn the A/C off, it stops. Any idea?
could be a compressor pulley. they commonly make noise and ive replaced a bunch of AC compressor pulleys for that. also the upper idler pulley whines too but will normally always make the noise regardless of the AC on or not.
