Blower Motor Fuse
Blower Motor Fuse
When I tried the blower motor on my 86 300e it didn't work. First thing I did was to check the fuse (#12) and the bottom of the fuse holder(?) seems to bel all melted. What could have caused it? I recently changed out the battery.
RE: Blower Motor Fuse
Probably not, on the early 124's the fuse heats up and melts into the fuse holder. The fix at the time was an externally mounted fuse holder that used a ribbon type fuse. The repair kit is probably still available. I'll check at work and see if I can come up with the part # tommorrow.
