'98 E320: horn beeps when key turned to 2nd postion
It's quite annoying when I have to start the engine and the horn beeps. I had reset the FSS thinking that this would solve the issue and turns out it didn't.
The locks were replaced a few months ago and prior to that I didn't have this problem. Could this be a contirbuting factor? :confused: Help PLEASE? |
the airbag needs to come off the wheel and then look at the horn contacts there. usually a new airbag is needed because the horn switch is part of the airbag asssembly but i would look at it and see how it works and see if you can tweek the horn contacts.
Originally Posted by Joefillipino
(Post 125189)
The locks were replaced a few months ago and prior to that I didn't have this problem. Could this be a contirbuting factor? :confused: Help PLEASE? Was this ever resolved? I just changed the FSE PUMP and now this has occurred with my car. When the pump is disconnected, the horn does not beep. |
