722.4 ATF & Differential Fluid Question
What is the Mercedes spec # for the ATF fluid on a 1993 300D with 722.4 transmission? I have read it is Dexron III, is this correct?
Also, what is the Mercedes spec # for the oil to be used in the differential? I'd like to use a synthetic.
Thanks - Brad
Thanks - Brad
If the ATF spec is 236.6 then Mobil Multi-Vehicle ATF will work.
Applications
Formally approved for:
Mobil Multi-Vehicle ATF is also suitable for use in vehicles that specify the following requirements:
Applications
- MERCONŽ V
- Allison C4 applications
- Audi G 052 025-A2, G 052 162-A1
- BMW LA2634
- Esso LT 71141
- ETL-7045E, ETL-8072B, N402
- Ford* MERCON*, MERCON LV
- All 2005 and earlier GM vehicles**
- Honda ATF-Z1*
- Hyundai SP-II, SP-III
- Idemitsu K17
- JWS 3309
- Kia SP-II, SP-III
- MAN 339F, V1, V2, Z1, Z2, Z3
- Mazda ATF-III, ATF-MV
- Mercedes-Benz 236.1, 236.2, 236.5, 236.6, 236.7, 236.9
- Mitsubishi Diamond SP-II, SP-III
- Nissan Matic-D, Matic-J, Matic-K
- Subaru ATF
- Toyota T-III, T-IV
- Voith 55.6335.XX (G607, G1363)
- Volvo 97340
- ZF TE-ML 03D, 04D, 09, 14A, 14B, 16L, 17C
You should get your ATF details by putting in the VIN in the following site:
http://old.mbclub.ru/mb/vin/?lng=eng
For diff, any synthetic with 75W to 90W will do.
mercedesdieselpetr
11-03-2013 04:49 PM
7224, atf, automatic, benz, correct, differential, e220, fluid, forums, kind, maticj, mercedes, oil, specification, transmission
