300TE Wagon Aux Fan Blows Fuse
My 300TE Wagon is overheating and I discovered that Aux fans were not coming on. Checked and found blown fuse. Replaced fuse and it blew again. Questions:</P>
1- How do you get to the Aux fan plugs to test the fans?</P>
2- Where is the Aux Fan Relay?</P>
3- Is there an Aux Fan resistor on this model</P>
4- Where is the Aux Fan Temperature switch?
</P>
There is a 16amp fuse on the block.
Mine was sort of melted and had sunk in a little bit.
I put in another fuse and the fan works.
Except, mine blew again after 2 months or so.
I am looking into way to see if the motor on the
auxiliary fan is going bad and has too much resistance.
Barry
Barry
