2004 E320 / Rear Sun Shade doesn't go down!
Hi, all.
As titled. I press the raise/low switch but the rear window sun shade wouldn't go down. I hear little click in the back (probably motor or switch clicking?), but no action. Luckily it is raised up right now so at least I can block the sun in the daytime.
Where should I look first? Could this be simple fuse problem? (I really hope so...)
I have an 05 doing the same thing. I worked on it today and if it is clicking your fuse is not blown. I did a few other tests and nothing. I'm going to work on it again tonight to see if I can find out what it is. Could be the relay. it is what is clicking in your trunk. I'll keep you posted
