2003/2004' E320
I just changed the oil on my 2000 E320 & manual says 8.5 quarts capacity. Before I drained the oil (thru the drain plug), i check the oil level using the FSS and it says "oil level ok.". However, I only got 6 quarts of old oil and just filled it with 7 quarts of Mobil 1 0W-40. There is a note on the oil cap not to exceed the max so as not to damage the engine. Does it mean that 2.5 qts is left in the engineor do I need to add 1.5 qts? After this, I used the FSS to check the oil level but gave me the message to turn on ignition - but it is already on! Using the dipstick, what is the correct oil level?? HELP!!
Salma2001
Oct 5, 2008 11:22 PM
