2000 E320 Climate Control
Old 04-29-2008, 02:57 PM
lciambotti's Avatar
Default 2000 E320 Climate Control
I am having a problem with the drivers side A/C. The passenger side blows cold, but the drivers side does not. It just seems to blow the outside air in. Anyone else have that issue and figure ou thow to fix it?
Old 04-29-2008, 11:36 PM
k_alavi's Avatar
Default RE: 2000 E320 Climate Control
This is most likely an indication of low gas presure in your AC system and a possible leak.
Check the presure or have it checked and if low,they can add a little gas that hasdye in itto look for the location of the leak.
Your control panel may gointo protective mode when presure is low and STAY on EC.
Old 04-30-2008, 12:31 AM
ohlord's Avatar
Banned
This is most likely an indication of a stuck duo-valve.A slight differential between pass and drivers side could be low R134a or a partly stuck duo-valve.A large difference that you describe is most likely the valve.
Run the onboard diagnostics
http://www.eclassbenz.com/node/27
post the values and errors
Give the duo-valves a firm tap on the sides with a screw driver handle most times that is all it takes to free up a stuck one.
They are the two tin can little beer can shaped units located with the electronics by the firewall in your passenger side engine compartment.
Get back to us with the a/c values 1-8,the error codes and the results of the whack.Don't dent them just a firm drum like tap
ohlord
Old 04-30-2008, 09:08 AM
lciambotti's Avatar
I'll check it out and report back.
Thanks a lot!!!
Old 05-05-2008, 11:40 AM
lciambotti's Avatar
The weather never got above 66 this weekend. I'll check things out this week. I didhowever check for the little beer cans valves, but couldn't locate anything that looked like them.Since it will be warmer this week, I'll take my time looking harder. I'll report back.
Leon
Old 05-05-2008, 03:53 PM
ohlord's Avatar
Banned
Give them a tap
http://www.benzworld.org/forums/w210...-cold-air.html
then run the diagnostics.
ohlord
Old 05-06-2008, 10:34 AM
lciambotti's Avatar
Ohlord,
That is a good link. Now I know where they are. I was looking for something bigger.
Old 05-08-2008, 04:13 PM
lciambotti's Avatar
It looks like I am a little bit low on R134. No leaks detected. I got a E B1234 (Sun Sensor Malfunction).
  #9
Old 05-08-2008, 05:40 PM
ohlord's Avatar
Banned
Don't pay attention to the sun sensor code it has no affect on the operation.
Toss in a can of r134a from any good auto store follow the instructions on the can.Post the results,should fix it.However it will happen again until you find and fix the small leak.
ohlord
from what you discribed I still think it is a stuck duo valve.
what was the value of #7 on the diagnostics?
  #10
Old 05-08-2008, 08:31 PM
lciambotti's Avatar
Number 7 was 07. I did take the duo valve apart, clean it, vasaline and put it back together again, before I did the diagnostics. I put a can of 134 in. I'll report back in a couple days.
Leon
Quick Reply: 2000 E320 Climate Control
