2000 E320 CD Changer Installation
you got D2B but not pre-wired.
you need to include the optic cable when installing additional accessories.
VIN WDB2102821X041641
Plant 61
Model E 320 4MATIC
Chassis 2102821X041641
Engine 112941 30 720079
Transmission 722664 12 139249
Tyres
Primary MICHELIN
Rear MICHELIN
Order 0 0 569 00974
Lights HELLA
Wiper BOSCH
Cab 00000
Delivery date 28.04.00
Dealer Sweden (569)
Interior leather anthracite (211)
Paint
753 tektite grey metallic
Options
228 auxiliary heater
auxiliary heater (с 01.11.1974)
auxiliary heater (only provision for installation in w 210)
236 special lamp switching - daytime running lamps (с 01.04.1985)
special light wiring for Norway and Sweden
249 automatically dipping inside rear view mirror (с 01.06.1990)
275 front seat positioned lower
memory package (driver's seat, steering column, mirror) (с 01.10.1993)
293 trunk set, 3-piece
sidebag in rear left and right (с 01.01.1995)
316 D-net telephone integrated (с 01.01.1995)
345 rains sensor for windshield wipers (с 01.10.1993)
352 operation and monitoring system comand (navigation + radio/cassette) (с 01.09.1996)
423 5 speed automatic transmission / nag (с 01.03.1994)
480 self-levelling suspension (с 01.03.1965)
543 sun visor with vanity mirror, illuminated, left and right (с 01.11.1978)
550 trailer coupling (с 01.03.1965)
551 anti-theft/anti-break-in warning system with anti-towing system (с 01.04.1998)
581 automatic climate control (с 01.01.1977)
600 headlamp wiper/washer (с 01.08.1971)
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978)
612 lamp unit: gas discharge lamp (ael)
xenon headlight (с 01.10.1993)
668
673 high-capacity battery (с 01.01.1964)
680 Unknown code
691 blue heat-insulating glass all round, rear window, single pane safety glass (с 01.02.1995)
800 Change of year of model, last figure shows new model year
825
873 seat heater for left and right front seats (с 01.02.1984)
876 interior light assembly (с 01.10.1997)
954 equipment package for avantgarde vehicles (с 01.06.1993)
rotating emergeny flasher, front (red light)
984 elimination of ownership certificate but with coc papers (с 01.06.1993)
Plant 61
Model E 320 4MATIC
Tyres
Primary MICHELIN
Rear MICHELIN
Order 0 0 569 00974
Lights HELLA
Wiper BOSCH
Cab 00000
Dealer Sweden (569)
Paint
Options
668
680 Unknown code
825
Hi Sleepwalker! I, too, have a 2000 E320. I have been trying tomake an OEMChanger work. I found the wirings & plug it into the changer, but lots of static. I tried cleaning the lens with a CD cleaner but the same result. Should the head unit be re-programmed? Any technique?? VIN # is WDBJF65J8YB009552. Thanks,
north american 210s should have come with the harness. simple enough to check for the
orange twin lead behind the left rear trunk panel. if the CD changer hasn't been installed
previously, the fiber harness may still be taped and secured with other analog wiring bundle
along the metal fender. it'll be less than a 5 min check
