1998 E 320 Catalytic Converter Rattle
I've got a 98 E 320 with 190K on the clock and the catalytic converters are making some rattling noise at idle. Have any of you had one or both of these replaced and did it solve the problem? Is it a urgent repair?
Thanks,
srb1194
Thanks,
srb1194
then test cat function.Sound like a can of gravel being shaken up?
Where are you located?universal cats can be spliced in for about $100 each including labor.
Time to change your o2 sensors as well.
![Arrow](https://mercedesforum.com/forum/images/icons/icon2.gif)
You can either try to splice in the racepages universal cats or you can ensure peace of mind and have an indie mechanic install the cat that is rattline. Installed you are looking at about $550 to $600 per cat. You should only need one. Find out which side is making the noise. Use OEM MB parts and you can't go wrong. Good luck. I hated my noisy driver's side cat before I couldn't take it anymore. Two local shops would not install the universal cats that I showed them. My indie mechanic will not use anything but MB parts.
![Cool](https://mercedesforum.com/forum/images/smilies/cool.gif)
You can either try to splice in the racepages universal cats or you can ensure peace of mind and have an indie mechanic install the cat that is rattline. Installed you are looking at about $550 to $600 per cat. You should only need one. Find out which side is making the noise. Use OEM MB parts and you can't go wrong. Good luck. I hated my noisy driver's side cat before I couldn't take it anymore. Two local shops would not install the universal cats that I showed them. My indie mechanic will not use anything but MB parts. ![Cool](https://mercedesforum.com/forum/images/smilies/cool.gif)
srb1194
ALLBIZNISS
11-19-2008 11:01 PM
