1993 300e 3.2
Old Apr 17, 2013 | 02:28 PM
mwink's Avatar
Default 1993 300e 3.2
New to the site with questions.Just bought a 1993 300e 3.2 with shift problems .The car has 190,000 but looks and runs great i bought it knowing that it had this problem .T car will shift once then when it starts to shift again the rpms goes up at that time you can let up some on the accelerator some and it will shift then in a moment it will make the last shift just like it is suppose to .Anybody have an answer to the cause of this
Mark
Old Apr 19, 2013 | 10:21 AM
PelicanParts.com's Avatar
Default Answer
My best guess:
It sounds like a vacuum issue.
* There is a problem with the Vacuum supply to the transmission modulator.
* The transmission modulator is damaged.
* The overload protection switch and/or O-ring are failing.
whunter@pelicanparts.com
Old May 16, 2013 | 07:41 AM
mwink's Avatar
Default update
unplugged modulator line at engine and drove car .The first shift was hard the second shift where the flare was happening at now has very little flare and hardly noticable at all but shifted hard.Does this indicate a bad modulator or something else?
Mark
Old May 17, 2013 | 09:17 AM
Default Answer
Originally Posted by mwink
unplugged modulator line at engine and drove car .The first shift was hard the second shift where the flare was happening at now has very little flare and hardly noticeable at all but shifted hard.Does this indicate a bad modulator or something else?
Mark
Replace and adjust the failing transmission vacuum modulator.
MB# 1262709179
http://www.pelicanparts.com/cgi-bin/...09179&x=13&y=8
Old Jul 2, 2018 | 08:51 PM
gregmerc300's Avatar
Hi I am new to the site I have a question my 300 runs fine but the check engine light came on and it refers to up shift what can this be it shifts fine"
bpdresser
Mar 7, 2020 05:21 PM
goalboy10
Jul 20, 2010 11:34 PM
parrotheadfl
Apr 2, 2005 10:46 PM
cisco
May 16, 2004 02:04 AM
snakes99
Mar 15, 2004 11:44 PM
