1990 300E failed on NoX and runs cold
My 1990 300E failed emission on NoX and engine temperature does not go more than 80-85. Can some one help if it the ignition timing or EGR or EGR pipe blockage. Also how to adjust timing.
RE: 1990 300E failed on NoX and runs cold
Have you replaced the thermostat?retard the timing a few degrees.Make sure the engine is up to operating temp before the test,even if you need to put a piece of cardboard in front of the radiator and pull it out before you go to the test station.
Thanks olord. I will try that. As well I am going to get the EGR and the EGR pipe cleaned by a mechanic just to be safe. I had valve seal problems as it was burning oil and had the seals replaced by Mercedes dealer in Kitchener, Ontario for $840.00. I have heard that if the EGR pipe is blocked by oil residue, the engine may run colder. After the valve job, when I accelerate, the tappets are slightly noisy. Does this mean that the timing has changed?
Thanks.
Thanks.
