1987 300E Neutral safety switch
Old 11-05-2004 | 08:09 PM
lprivee's Avatar
Default 1987 300E Neutral safety switch
Can someone please help me with finding the switch. Is it under the car or do I get to it through the shift console. I need to adjust or replace this part as the car will not start in Park or Neutral. I have to hold the ignition to start and carefully move the gear shift from neutral to drive until the starter turns.
Old 11-05-2004 | 09:36 PM
sleepwalker's Avatar
Default RE: 1987 300E Neutral safety switch
it is on the right side of the transmission.
under the car.
you will see a white flat thing there where the shift rod is attached.
Old 11-06-2004 | 03:02 PM
lprivee's Avatar
Thank you very much for the reply. Have a trailor rented for Sunday and maybe now I will be able to adjust it to get the car started.
Old 11-06-2004 | 08:53 PM
no need for the trailer.
just bypass the switch just for the car to drive to the workshop.
pull the connector out, jumper the two terminals, start the car, and plug it back.
also loosen the two small bolt, adjust it to a advance/retard position (whichever works), and tight it back. just make a slight adjustment.
djgonzo
08-25-2009 04:11 PM
88silver300e
01-03-2009 10:03 PM
dsmoss
09-28-2007 06:00 PM
pguard
01-20-2007 01:52 AM
BlackWolf
07-18-2006 08:43 AM
Quick Reply: 1987 300E Neutral safety switch
