1986 300e idling problem
Old Jul 2, 2010 | 05:18 PM
repanzer's Avatar
Default 1986 300e idling problem
I have an 86 300e, I have replaced the fuel pump and filter, but the idle goes up and down now, did not before the new pump, it was very noisy. can you tell me what to check next? thanks
Old Jul 3, 2010 | 11:56 AM
BigSkyBenz's Avatar
I'm guessing this is fuel injected, correct? I would consider the fact that your fuel pump may actually have been bad, but besides that, you may want to look at:
Idle Controller (if you have one--I'm not familiar with this year)
Possible fuel leak somewhere (gaskets, lines, etc etc)
Check fuel pressure while running and see if it correlates with your rpm jumps.
Good luck!
Old Jul 3, 2010 | 08:43 PM
repanzer's Avatar
I have checked the fuel pressure, the original problem was stalling at take off, replaced the filter, pump, screen, hoses and the overload relay. Cars runs smooth down the road but the idle goes up and down, I am wondering about the idle control sensor? Such a pain it has no computer connection, cant read codes...
Old Jul 4, 2010 | 07:34 AM
repanzer's Avatar
can someone tell me what an idle control valve is and how to tell it is bad?thanks
Old Jul 7, 2010 | 11:07 AM
mbenz80's Avatar
I believe idle control valve on these was screwed into side of the block under the intake manufold, sensing coolant temperature and opening/closing air supply. It would not make the RPM fluctuate because it is working in very slow motion and it is closed when engine is warmed up. Check all the clamps on fuel hoses to pump and tank, you may be sucking air into fuel while pumping it out of tank. You can check your new pump by taking off supply hose from fuel distributor, volume should be one quart of fuel minimum per 30 seconds. There is also screen in the fuel distributor inlet where the supply hose fitting is screwed into and also in warm up regulator under supply hose fitting. Follow the fuel line from pump to engine and you will find them.
Old Jul 14, 2010 | 03:56 PM
david hendy's Avatar
Either your idle valve is bad or you have numerous vacuum leaks.
Under the air filter assembly you will see a silver tube like object, say 4" long with two 1" hoses running to it, Its about 1 1/2" diameter, shaped like a cylinder.
Also all the vacuum lines need to checked for leaks.
As for how to check it? Tough. Get one off ebay for $30 & see if it helps.
I may have one, I'll check. After 20 odd years my money is on the vacuum lines being shot.
Old Nov 23, 2010 | 12:18 PM
repanzer's Avatar
thanks for the help, sorry it took so long to get back..it was the idle control, and the fuel pressure accumulator...
jzbrick
Oct 13, 2011 08:52 AM
ozizzel
May 27, 2009 05:24 AM
nabiil
Feb 8, 2007 08:39 AM
beamer
May 18, 2006 03:13 PM
korte4260
Apr 1, 2005 04:27 PM
