"Rev what?" Sleepwalker? Anyonnne? E320
I recently backed 94 E320 into a ditch and when I did I hit the fuel line..? When I would accelerate hard from standstill she'd 'hiccup' and shake..soooo took her in to a shop and had them fix whatever I severed, put in new plugs and wires and clean fuel system. Now she is fine EXCEPT when you're on the interstate and you floor it around 65-70 mph she starts that shuddering again and won't gain speed..I took her back to shop and guy said it had something to do with the "Rev something somethin"??...that the rev meter or something is set at a certain timing?...What?? It never did this before so I'm wondering if anyone knows what this "Rev sensor or meter or whatever" situation is and if that could be my problem. She idles fine, runs fine, just at high rpm you can't stomp on her anymore..if you do she shudders and you have to let off and ease the accelerator down....Anyone?
you are aware of the speed limiter setting right? (LIM)
maybe you don't have that function, but in your model the speed limiter could not be set by diagnosis computer...only manually.
can you rev the engine past 4000rpm at standstill? does the fuel pressure drops (below 1.8bar) while doing it?
no kinked fuel line?
Hmmm..I'll try to rev at standstill today...where is the speed limiter setting and how is this changed? This also didn't happen before just suddenly..so can the LIM just go out of whack one day or worse..go bad? Thanks again
~Dehaven
~Dehaven
Sleepwalker...tried revving her past 4000rpm this morning in park..she WONT do it..she stops there and shudders...is it the LIM,, and is this a simple DIY or do I need to take her in? Thanks man,
~Dehaven
~Dehaven
got cruise control but no speed limiter.
can rev up to 4000rpm but cannot run more than 70m/h... the fuel filter is new?
VIN WDBEA32E5RC098871 Model E320 Chassis 1240321C098871 Engine 104992 12 046191 Transmission 722369 03 951923 Order 0 4 704 30578 Approx. year not defined Lights BOSCH Wiper BOSCH Cab 00000 Dealer United States (USA) (704) Interior leather grey / orion gray (268) Paint 744 brilliant silver metallic (с 1991) 68 Unknown code Options 222 right front seat, electrically adjustable (с 01.11.1978)
first aid kit (с 01.11.1962 по 30.09.1970)
240 outside temperature indicator (с 01.03.1982)
second spare wheel (с 01.01.1964 по 28.02.1973)
241 left front seat electrically adjustable with memory feature. only applicable to w 210 when installed in conjunction with code 275. (с 01.03.1983)
wood rims (с 01.01.1964 по 31.08.1971)
251 Becker Radio Mexico cassette, full stereo, electronic (с 01.04.1980 по 30.11.1990)
Becker Radio Grand Prix TR with remote control and automatic antenna (с 01.04.1964 по 31.05.1977)
radio MB-Exquisit - USA (с 01.07.1992)
280 trunk set, 3-piece (с 01.09.1964 по 31.08.1972)
steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (с 01.05.1984)
291 airbag for front passenger
airbag for front passenger (с 01.10.1993)
airbag for driver and front passenger (с 01.07.1987 по 30.09.1993)
airbag for driver and front passenger (if driver airbag standard - then only for passenger)
garment trunk, large (с 01.02.1967 по 31.05.1973)
trunk set, 7-piece (с 01.01.1976 по 31.08.1978)
300 storage box in front tray (с 01.05.1988)
taxi design without compartment wall, taximeter instrument panel (с 01.01.1968 по 31.07.1968)
340 additional 3rd stop lamp (с 01.10.1989)
front seat, right, lower (с 01.03.1967 по 28.02.1986)
412 electric sliding roof with tilting device (с 01.07.1983)
hydraulic sliding roof, in the rear (с 01.11.1964 по 30.06.1981)
420 automatic transmission, floor shift (с 01.01.1963)
430 headrests in the rear (с 01.01.1977)
safety belts, front and rear (с 01.01.1964 по 31.05.1973)
443 bumpers, front and rear, with guards (с 01.01.1963 по 29.02.1968)
tempomat (cruise control), and steering column, electrically adjustable (с 01.07.1984)
441 + 442 (с 01.10.1969 по 30.09.1970)
461 instrument with mileage reading and english lettering (с 01.04.1990)
494 California version
California version (с 01.05.1973 по 31.12.1995)
version for USA/California/Canada (с 01.01.1996)
490 + 492 (с 01.12.1966 по 30.09.1967)
524 Reims adapter IV (с 01.04.1962 по 28.02.1963)
paintcoat preservation (с 01.01.1964)
543 exhaust-pipe cover trim (с 01.01.1963 по 28.02.1963)
seat adapter between the front seats, and halogen lamp unit (с 01.01.1967 по 31.12.1972)
sun visor with vanity mirror, illuminated, left and right (с 01.11.1978)
551 anti-theft warning system (с 01.11.1978 по 31.03.1998)
anti-theft/anti-break-in warning system with anti-towing system (с 01.04.1998)
steering wheel, ivory-colored (с 01.01.1963 по 31.05.1973)
588 Thermoking air conditioner and electric window lifters (front doors) (с 01.04.1970 по 31.12.1972)
automatic climate control and electric window lifters (front and rear doors) (с 01.01.1977)
593 headlamp flasher and turn signal lamps - italy (с 01.01.1963 по 31.07.1965)
headlamp flasher and turn signal lamps, front, crystal clear (с 01.08.1965 по 31.01.1967)
heat-insulating glass, rear window pane (с 01.02.1967 по 31.01.1971)
heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978)
sealed beam lamp unit, l.h. traffic (с 01.01.1966 по 28.02.1972)
lamp unit, symmetrical (с 01.01.1962 по 28.02.1963)
639 radial-ply tires, elimination of warning triangle (с 01.11.1973 по 31.10.1974)
elimination of first-aid box and warning triangle (с 01.08.1977)
652 Dunlop tires (с 01.01.1963 по 31.07.1972)
8-hole light alloy rims (с 01.01.1990)
668 662 + 666 (с 01.01.1963 по 28.02.1963)
804 Change of year of model, last figure shows new model year
810 roof-mounted loudspeaker (с 01.11.1962 по 30.11.1972)
loudspeaker, sound package
sound package (bose) (с 01.12.1986)
916 cabel routing for second battery (с 01.03.1966 по 31.10.1971)
front wheel hub suppression (с 01.04.1964 по 31.10.1965)
that's informative thanks..alright..the cruise control doesn't work but I've never minded..and yeah the fuel filter was replaced when the new plugs/wires/ and cleaning of fuel system was done...could it be the fuel pump?
warsawwizard
11-10-2004 04:25 PM
