tilt wheel
usually you can go all the way up and all the way down and hold it at each place then try to go in and out. again, try the procedure a few times and you might have some luck. the colummn looses its normalization and needs to be relearned. but you also could have a bad switch or motor.
your 2005 c240 is different than his clk its a different set up. you most likley have a broken rubber piece that is used to move the wheel up and down. you can try the same procedure as i told him and it might work. but your c240 has commom issues with the rubber "rods" breaking
Hi again,
Thank you ver much for your geat help!
I better check around where I should bring!
Living in Hawaii, everything seems like more higher.....the labor fee at Mercedes Benz Dealer in Hawaii is $125 per hour now.
Today the Dealer gave the estimate is $1,000(part & 4 hours lobors).
Again thank you very much and I really appreciate your help!
