Problem with CLK320 Door / Window
Old Sep 4, 2005 | 03:48 PM
dcstreetrods's Avatar
Default Problem with CLK320 Door / Window
Hello:
We recently purchased a 1998 CLK320. When we purchased the car the driver's side door was hard to close because it had sagged a few degrees. We had it adjusted by a local Mercedes mechanic. It now appears that the window in that door is travelling too far up and keeping the door from closing without slamming it. Has anyone run into this problem? Is the window travel adjustable? If so, can you give me instructions on how to do the adjustment. (Note: I have already found a good description of how to remove the door panel on this forum.) Thanks for any help you can provide.
DCStreetrods
Old Sep 4, 2005 | 11:11 PM
sleepwalker's Avatar
Default RE: Problem with CLK320 Door / Window
you need to reinitialize it.
removing the battery for two minutes will denormalize the window and normalize it by using the switch.
Old Sep 26, 2006 | 05:43 PM
a74642's Avatar
HI, I also need to take the door panel off but can't find anything to help me out. Have a CLK320 2000. Any help would be appreciated. JS
richardrud
Sep 8, 2011 12:35 PM
painter8
Jun 29, 2010 08:08 AM
stasha
Oct 22, 2007 03:33 PM
linselpr
Aug 30, 2005 02:37 PM
Anticyber
Jul 8, 2005 07:39 AM
