Maintenance Schedule
RE: Maintenance Schedule
Since you didn't post the year of your vehicle This may not be exact --> This info is based on a 2000 CLK320
You don't really have a 60,000 mile maintenance interval
You have a two types of maintenance A & B
In addition to whichever service interval you are do for At approximately every 60,000 miles/96,000 km or 4 years, you also perform the following:
- Replace fuel filter.
- Replace air cleaner filter element.
The A & B Services are Outlined Below:
Maintenance: Service Intervals
A - Service Schedule
Vehicle Passenger Compartment Function Check:
- Horn, headlamp flasher, hazard flasher, turn signals.
- Warning/indicator lamps, illumination and interior lighting.
- Exterior lighting incl. headlamps.
- Windshield wipers, windshield washer system.
- Headlamp cleaning system.
- Check seat belts for damage and proper function.
- Reset Flexible Service System (FSS) counter in instrument cluster.
- Replace dust filter.
Wheels, Brakes
- Check thickness of brake pads by removing and reinstalling right front wheel.
- Check thickness of brake discs by removing and reinstalling right front wheel.
- Check tires for damage and condition.
- Measure and record tread depth.
- Correct tire inflation pressure.
Engine Compartment
- Engine oil and filter change.
- Check and correct fluid level:
- Engine cooling system, antifreeze and corrosion protection.
- Brake system.
- Windshield washer.
- Lubricate catch, safety catch and hinges on engine hood.
Trunk
- If so equipped: Battery, wet cell; Check acid level, replenish.
- Check battery condition using "Midtronics MCR 717" Tester.
- Correct tire inflation pressure in spare tire.
__________________________________________________ ___________
B - Service Shedule
Brake Test
- Brake test on dynamometer or test drive. Check parking brake and run in according to specifications (on vehicles with 4MATIC, ASR, ETS, ESP observe instructions in Maintenance Manual!).
Function Check:
Wheels, Brakes
- Remove and reinstall wheels, rotate if necessary, does not apply for vehicles with different tire sizes front/rear.
- Check brake pads for lining thickness front/rear.
- Check condition of brake discs front and rear.
Vehicle Underbody
- Visual check for:
- Leakage - Major components.
- Chafe marks, line routing, components.
- Check condition of front axle ball joints.
- Check condition of steering's mechanical components.
Engine Compartment
- Visually check:
- Leakage
- Major components.
- Brake system.
- Power steering.
- A/C refrigerant level.
- Windshield washer system.
- Check condition of poly-V-belt.
- Lubricate throttle linkage, check function and condition.
Front, Rear of Vehicle
- Inspect headlamp range adjustment of headlamps (NOT for xenon headlamps).
- Inspect headlamp setting, adjust to correct setting.
- Replace windshield wiper rubber inserts.
Trunk
Wheels, Brakes
Engine Compartment
- Brake system.
Trunk
B - Service Shedule
Brake Test
Function Check:
Wheels, Brakes
Vehicle Underbody
- Visual check for:
Engine Compartment
- Visually check:
- Leakage
- Major components.
- Brake system.
- Power steering.
Trunk
