Instrument Cluster Piece Loose
Old Jan 18, 2006 | 02:50 AM
Napster's Avatar
Default Instrument Cluster Piece Loose
A small piece on the left side of the instrument cluster which displays the ABS and brake light indicator lights came loose and dropped about 1/4 inch. It has a small hole at the top which looks like it would snap onto a small peg. Is this an easy fix or needs a professional to fix it? Thank you in advance for any suggestions.
Old Jan 24, 2006 | 11:13 PM
tric1's Avatar
Default RE: Instrument Cluster Piece Loose
if you can take the instrument cluster out it wouldn't be hard. you will need instrument cluster hooks and have to be careful when pulling with the hooks- make sure the point on the hooks are facing the cluster and not the dash- ive seen more than one dash have to be replaced or repaired from accidents. also move the steering wheel as far out and down as possible.
jerzstyle00
Apr 22, 2011 10:05 PM
sleepwalker
Mar 24, 2007 11:47 PM
danj111
Oct 16, 2005 01:16 PM
CLK500KID
Oct 29, 2004 12:24 AM
