Headrest Removal CLK430
Bought some new sheepskins, but need to remove the headrest to install them--anyone have a clue how to release the headrests so this seemingly simple job can be completed? Thanks!
RE: Headrest Removal CLK430
tilt the backrest forward,raise headrest as far up as possible,then just pull off,they will come right out.
I tried what you said, but no luck? I tried it two ways, (i) moved the backrest of the front seat forward using the release mechanism then raised the headrest but would not come out. Then I returned the seat and used the seat adjustment to move the backrest as far forward as possible and then raised the headrest--same result--the headrest did not come out??? Any other suggestions...thanks!
you have to pull hard from side to side,thats how mine came out after tilting forward,in order to install my sheepskins
