Disk Brake Thickness
25.4mm front 8.3mm rear, thats a common spec on them, if its a benz rotor it willl be stamped on the rotor . you can see it without removing the wheel. its where the rim and hub meet together. might be hard to see...rust, dirt etc. youll see a MB emblem then a part # then the MIN THK 25.4mm same with the rears.
