clk camber adjustment
Old May 9, 2007 | 01:15 PM
devine.clk's Avatar
Default clk camber adjustment
hi,im wondering can my 2001 clk200 coupes camber be adjusted as i have put lowering spring in and its eating the inside of the tyres?car is driving dead straight and not pulling left nor right.
Old May 9, 2007 | 04:43 PM
BAYAREAGLASS's Avatar
Default RE: clk camber adjustment
when you put lowering kit in did you take it to the front end shop? if not you should, lowering it changes everything
Old May 11, 2007 | 05:16 PM
devine.clk's Avatar
i have had the car in for 4 wheel alignment and the guys there said the camber is off a mile and the suspension cannot be adjusted to sort this.I am told that mercedes main dealer will have to change original bolts in suspension to adjustable bolts so that camber can be rectified.I have contacted local main dealer and booked her in to get sorted.p.s for all u guys out there its not so simple just throwing on a set of 19's and a set of springs
Old May 21, 2007 | 12:33 PM
K1MOTORSPORT's Avatar
We have K-MAC camber kits available to correct negative camber issues.
rocorn
Mercedes A Class
May 26, 2011 02:57 PM
drblank
Oct 11, 2006 02:19 PM
edl100
Jul 24, 2005 07:38 AM
warsawwizard
Nov 5, 2004 04:32 PM
choppers_rule
Dec 30, 2003 03:38 PM
