2004 CLK320 (M112) water pump replacement
The pully on my water pump seems to be running out of true so serpentine belt is catching the engine casting.
3 Questions.
1) How do I take the tension off the belt so I can remove it and investigate problem?
2) Is the water pump running out of true a common problem?
3) Are there any particular issues to be aware of when replacing the water pump?
Any help gratefully accepted, thank you
3 Questions.
